Certificate authentication for AWX Tower gives error when running Ansible playbooks
Applies to
- ONTAP 9
- AWX Tower
Issue
Unable run ansible playbooks as they result in error:
An exception occurred during task execution. To see the full traceback, use -vvv. The error was: netapp_lib.api.zapi.zapi.NaApiError:NetApp API failed. Reason - URL error:URLError(SSLError(1, '[SSL: TLSV1_ALERT_UNKNOWN_CA] tlsv1 alert unknown ca(_ssl.c:1131)'))fatal: [localhost]: FAILED! => {"changed": false, "msg": "Error fetching volume test_awx : NetApp APIfailed. Reason - URL error:URLError(SSLError(1, '[SSL: TLSV1_ALERT_UNKNOWN_CA] tlsv1 alert unknown ca (_ssl.c:1131)'))"}
