NetApp Knowledge Base
Can we modify the max dir on DP volume if max dir alert received
69
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF system
Answer
  • Maxdir size cannot be modified on a DP volume as it is a read-only.
  • The Maxdir size on the DP volume will change to the value set on the source volume after the resync
