NetApp Knowledge Base
Can volume modification commands be executed in a cluster running mixed ONTAP versions?
40
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • volume modify -size -percent-snapshot-space command
Answer
  • Yes. Both CLI-based and REST API-based volume modification operations can be safely executed in a cluster with mixed ONTAP versions
  • Please ensure that all parameters are aligned with the oldest node’s version specification. This guarantees compatibility and avoids parameter-related errors.
