NetApp Knowledge Base
AutoSupport fails using SMTP transport with "530 5.7.57 SMTP Client was not authenticated"
2,280
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport configured with SMTP transport
Issue
  • AutoSupport SMTP failure.
    Example:
::> system node autosupport history show -node FCFN0101 -instance output
transmission-failed: Failed sending data to the peer
  • SMTP; Client was not authenticated to send anonymous mail during MAIL FROM error message found.
    Example:
::> node run -node node_name -command rdfile /etc/log/mlog/notifyd.log
Mon Apr 25 2022 01:34:43 +02:00 (message: SMTP 0x808a47648 state change from EHLO to STOP)
Mon Apr 25 2022 01:34:43 +02:00 (message: STATE: PROTOCONNECT => DO handle 0x808f2c008; line 1611 (connection #0))
Mon Apr 25 2022 01:34:43 +02:00 (message: DO phase starts)
Mon Apr 25 2022 01:34:43 +02:00 (message: MAIL FROM: from_email@domain.com)
Mon Apr 25 2022 01:34:43 +02:00 (message: SMTP 0x808a47648 state change from STOP to MAIL)
Mon Apr 25 2022 01:34:43 +02:00 (message: STATE: DO => DOING handle 0x808f2c008; line 1660 (connection #0))
Mon Apr 25 2022 01:34:43 +02:00 (message: 530 5.7.57 SMTP; Client was not authenticated to send anonymous mail during MAIL FROM)
Mon Apr 25 2022 01:34:43 +02:00 (message: MAIL failed: 530)
Mon Apr 25 2022 01:34:43 +02:00 (message: DO phase failed)
Mon Apr 25 2022 01:34:43 +02:00 (message: multi_done)
Mon Apr 25 2022 01:34:43 +02:00 (message: Marked for [closure]: SMTP done with bad status)
Mon Apr 25 2022 01:34:43 +02:00 (message: QUIT)
Mon Apr 25 2022 01:34:43 +02:00 (message: SMTP 0x808a47648 state change from MAIL to QUIT)
Mon Apr 25 2022 01:34:43 +02:00 (message: response reading failed)
Mon Apr 25 2022 01:34:43 +02:00 (message: Closing connection 0)
Mon Apr 25 2022 01:34:43 +02:00 (message: The cache now contains 0 members)
Mon Apr 25 2022 01:34:43 +02:00 (message: Expire cleared)
on Apr 25 2022 01:34:43 +02:00 (message: Failed to transmit smtp asup 4677, curl error: Failed sending data to the peer)
New to NetApp?
