NetApp Knowledge Base
Auto-provisioning aggregate fails due to not enough spare disks with matching RPM
2,182
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9.8
  • ONTAP 9.9.1
Issue
  • Aggregate auto-provision command fails with the following error:
Error: Provisioning "Cluster_1_01_aggr_1" failed. Reason: [Job 452] Job failed: Failed to create aggregate "Cluster_1_01_aggr_1" on "Cluster-1-01". Reason: There are not enough spare disks with matching RPM. 11 disks needed from one pool, but not enough matching disks of the requested size are available in either pool.
  • Example:
Cluster-1::> aggr auto-provision -verbose
Per node summary of new aggregates to create, discovered spares, and also
remaining spare disks and partitions after aggregate creation:
New    Total New -Discovered Spare- -Remaining Spare-
Node               Aggrs  Usable Size  Disks  Partitions  Disks Partitions
Cluster-1-01           1      13.05TB      0          12      0          1
Cluster-1-02           1      13.05TB      0          12      0          1
Total:                 2      26.10TB      0          24      0          2
New data aggregates to create with counts of
disks and partitions to be used:
Is    Usable  -Devices To Use-
Node            New Data Aggregate        Mirrored      Size  Disks Partitions
Cluster-1-01    Cluster_1_01_SAS_1           false   13.05TB      0         11
Cluster-1-02    Cluster_1_02_SAS_1           false   13.05TB      0         11
RAID group layout showing how spare disks and partitions will be used
in new data aggregates to be created:
RAID Group In New                      Disk       Usable Disk Or   ---Count---
Data Aggregate To Be Created           Type         Size Partition Data Parity
/Cluster_1_01_aggr_1/plex0/rg0          SAS        1.61TB partition    9      2
/Cluster_1_02_aggr_1/plex0/rg0          SAS        1.61TB partition    9      2
Details about spare disks and partitions remaining after aggregate creation:
Disk         Device Disk Or   Remaining
Node               Type    Usable Size Partition    Spares
Cluster-1-01       SAS          1.61TB partition         1
Cluster-1-02       SAS          1.61TB partition         1
Do you want to create recommended aggregates? {y|n}: y
Info: Aggregate auto provision has started. Use the "storage aggregate show-auto-provision-progress" command to track the   progress.
Cluster-1::> storage aggregate show-auto-provision-progress
Current       Target
Aggregate                     Usable Size  Usable Size Provisioning Progress
Cluster_1_01_aggr_1                     0B      13.05TB Failed
Cluster_1_02_aggr_1                     0B      13.05TB Failed
Error: Provisioning "Cluster_1_02_aggr_1" failed. Reason: [Job 453] Job failed: Failed to create aggregate "Cluster_1_02_aggr_1" on "Cluster-1-02". Reason: There are not enough spare disks with matching RPM. 11 disks needed from one pool, but not enough matching disks of the requested size are available in either pool.
New to NetApp?
