Are ONTAP cluster shell modify settings persistent across reboot?
Applies to
ONTAP 9
Answer
Yes. Cluster shell commands that modify settings (such as system services firewall modify
, storage raid-options modify
, etc.) are persistent after reboot.
Additional Information
Cluster shell modify commands update relational database (RDB) tables and sync across the cluster interconnect to ensure settings are persistent and consistent.
Example:
cluster::> system services firewall show
Node Enabled Logging
cluster-1a true false
cluster-1b true false
2 entries were displayed.
cluster::> system services firewall modify -node * -enabled false
2 entries were modified.
cluster-1a false false
cluster-1b false false
cluster::> storage failover takeover -ofnode aff200-rtp-1b
System rebooting...
login: admin
Password:
