NetApp Knowledge Base
After LIF failover, CIFS outage with EMS logging secd.cifsAuth.problem because LIF cannot reach name services
82
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
nas
Last Updated:
Applies to
  • ONTAP 9
  • routing
  • LIF failover group/policy
  • broadcast domain
  • CIFS/SMB
Issue
  • After LIF failover (e.g. ONTAP upgrade) CIFS clients cannot access data via either \\hostname or \\ip
  • ActiveIQ detects Risk Signature: 2226
    • Risk: All ports in a broadcast domain should be on the same layer 2 network.
    • Details: Broadcast domains(s) "<name>" contains port from multiple vlans.
  • LIF is in broadcast domain that contains multiple VLANs
    • ::> network port broadcast-domain show -broadcast-domain Storage
      IPspace Broadcast                                         Update
      Name    Domain Name    MTU  Port List                     Status Details
      Default Storage       1500
                                  cm8080-rtp-04:a0d             complete
                                  cm8080-rtp-02:a0d             complete
                                  cm8080-rtp-02:e0i-40          complete
                                  cm8080-rtp-03:a0d             complete
                                  cm8080-rtp-01:a0d             complete
                                  cm8080-rtp-01:e0i-40          complete
  • LIF is in failover group that contains failover targets that are from multiple VLANs
    • ::> net int show -failover -vserver svm1
        (network interface show)
               Logical         Home                  Failover        Failover
      Vserver  Interface       Node:Port             Policy          Group
      svm1
               LIF_A           node-02:a0a           Default           Default
                                   Failover Targets: node-02:a0a, node-02:a0a-453,
                                                     node-02:a0a-700, node-02:e0M,
                                                     node-01:a0a, node-01:a0a-453,
                                                     node-01:a0a-700, node-01:e0M
  • EMS contains
    • [?] Tue Jul 01 11:40:15 +0530 [node-01: secd: secd.dns.srv.lookup.failed:error]: DNS server failed to look up service (_ldap._tcp.dc._msdcs.apac.contoso.com) for vserver (svm1) with error (Connection refused).
    • [?] Tue Jul 01 11:40:15 +0530 [node-01: secd: secd.cifsAuth.problem:error]:
      vserver (svm1) General CIFS authentication problem.
      Error: User authentication procedure failed
      CIFS SMB2 Share mapping - Client Ip = x.x.x.x
      [ 0 ms] Login attempt by domain user 'domain\user' using NTLMv2 style security
      [ 2] TCP connection to ip x.x.x.x, port 389 failed: No route to host.
      [ 2] LDAP search for the "dnsHostName" attribute(s) within base "" (scope: 0) using filter "(objectClass=*)" failed with error: Can't contact LDAP server
      [ 2] TCP connection to ipx.x.x.x, port 389 failed: No route to host.
      [ 3] LDAP search for the "dnsHostName" attribute(s) within base "" (scope: 0) using filter "(objectClass=*)" failed with error: Can't contact LDAP server
      [ 3] TCP connection to ip x.x.x.x, port 389 failed: No route to host.
      [ 5] Failed to connect to x.x.x.x for DNS via Source Address y.y.y.y: No route to host
      [ 6] Failed to connect to x.x.x.x for DNS via Source Address y.y.y.y: No route to host
      **[ 7] FAILURE: Unable to contact DNS to discover domain controllers.
      [ 8] Unable to make a connection (NetLogon:domain.contoso.COM), Result: RESULT_ERROR_DNS_CANT_REACH_SERVER
      [ 8] CIFS authentication failed
New to NetApp?
