NetApp Knowledge Base
ActiveIQ indicates discrepancy between WAFL and VLDB for foreign aggr0
106
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • ActiveIQ
Issue
  • ActiveIQ indicates discrepancies between WAFL and VLDB, referencing aggregate aggr0 present in WAFL only.
  • The debug vreport show command indicates the following:
::> set diag
::*> debug vreport show
aggregate Differences:
Name             Reason   Attributes
aggr0(c71f3771-497d-42c5-b639-504892d29728) Present in WAFL Only
                 Node Name: Cluster01-01
                 Aggregate UUID: c71f3771-497d-42c5-b639-504892d29728
                 Aggregate State: offline
                 Aggregate Raid Status: raid_dp, foreign
                 Aggregate HA Policy: cfo
                 Is Aggregate Root: true
                 Is Composite Aggregate: false
 Fix Recommendation: Use "storage transition aggregates start" command to transition the aggregate which would fix this discrepancy.
New to NetApp?
