nvmem.battery.voltageLow is reported and recovers automatically
Applies to
- AFF-C250
- ONTAP 9.14.1P4
- BMC FW 15.11
Issue
- EMS reports the
error
[nvmem.battery.voltageLow:EMERGENCY]: The NVMEM battery voltage is critically low (3550 mV). To prevent data loss, the system will shut down in 5 minutes.
- Alert is cleared and battery reading normal shortly after
[nvmem.battery.voltage.normal:info]: The NVMEM battery voltage is normal.
[monitor.shutdown.cancel:notice]: Automatic shutdown sequence canceled.
- Following events can be seen in BMC event logs:
5df | 01/01/2000 | 00:00:19 | Battery #0x4a | State Deasserted
5e0 | 01/01/2000 | 00:00:19 | Battery #0x4b | State Asserted
5e1 | 01/01/2000 | 00:00:19 | Battery #0x4c | State Asserted
5e2 | 01/01/2000 | 00:00:19 | Battery #0x4d | State Deasserted
5e3 | 01/01/2000 | 00:00:19 | Other FRU #0x50 |
5e4 | 01/01/2000 | 00:00:19 | Other FRU #0x50 |
5e5 | 01/01/2000 | 00:00:19 | Other FRU #0x50 |
5e6 | 01/01/2000 | 00:00:19 | Other FRU #0x50 |
5e7 | 01/01/2000 | 00:00:25 | Power Supply #0x20 | Presence detected | Asserted
5e8 | 01/01/2000 | 00:00:25 | Power Supply #0x25 | Presence detected | Asserted
5e9 | 01/01/2000 | 00:00:25 | Power Supply #0x72 | Presence detected | Asserted
5ea | 01/01/2000 | 00:00:25 | Power Supply #0x73 | Presence detected | Asserted
5eb | OEM record f2 | Watchdog1 Timeout
5ec | OEM record f2 | Pilot Software reset
5ed | 01/01/2000 | 00:00:39 | Battery #0x4f | State Deasserted
5ee | 01/01/2000 | 00:02:19 | System Event #0xff | Timestamp Clock Sync | Asserted
5ef | 09/12/2024 | 05:35:54 | System Event #0xff | Timestamp Clock Sync | Asserted
5f0 | 09/14/2024 | 05:35:52 | System Event #0xff | Timestamp Clock Sync | Asserted
5f1 | 09/14/2024 | 05:35:54 | System Event #0xff | Timestamp Clock Sync | Asserted
- Alerts are seen outside of a learning cycle.
