X1155 SAS adapter port 1c amber LED light on both nodes of HA cluster
Applies to
- AFF-A250, FAS500f
- X1155 12Gb SAS,4-port
- Firmware Versions:14.00.00.00
Issue
- On a AFF-A250 storage system, slot 1 SAS port 1c amber "Attention" LED is lit on both nodes of the HA system.
- There are no observed impacts on the system's performance.
- Even if all SAS cables are removed from the card, the Attention LED for port 1c remains lit.
- The green "Link" LED has a different lighting status than expected.
- Regardless of whether the cable is connected or disconnected, there is no change in the LED status.
Example:
SAS cable connection:
- Connected to port 1 and port 4
LED:
- Green LED: Only port 1 and port 3 are lit
- Amber LED: Only port 3 is lit
