NetApp Knowledge Base
Why there is a difference between volume show command output and df command output for volume whose filesys-size-fixed is true?
359
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • filesys-size-fixed volume option is True
Answer
This is expected behavior.
  • df command output doesn't report the real size for the volume whose -filesys-size-fixed option is true.
  • This option is used to keep the size of DP volume after breaking snapmirror relationship.
