What will be the impact of executing command "system switch ethernet delete"?
Applies to
- ONTAP 9
- Cluster Network switch
Answer
- The
system switch ethernet deletecommand is used to delete an Ethernet switch. This command is intended to be used to delete a switch that has been disconnected from the system, instead of waiting for it to be deleted automatically. -
This command only removes a switch entry from ONTAP's Cluster/Storage Switch Health Monitor (CSHM) table.
- The physical switch continues to operate normally and pass traffic. Cluster communication, management access, and client data access are not disrupted.
- The switch can be re-added to monitoring using
system switch ethernet create.
Additional Information
additionalInformation_text
