What are AC power cables and common IEC 60320 connector types
Applies to
- Servers
- Storage Systems
- Network Equipment
- PDUs
- Any related power infrastructure including power cords
Answer
Overview
- A power cable is used to supply alternating current (AC) electrical power from a power source (such as a wall outlet, power strip, or power distribution unit) to a device so it can operate
- The connector types described in this article are defined by the IEC 60320 standard, which applies only to AC power connections. IEC 60320 connectors are not used for DC power delivery
- IEC 60320 defines standardized appliance couplers, including connector shape, orientation, and maximum electrical ratings, to ensure compatibility and safe use across regions and vendors
Common IEC 60320 AC connector types
The ratings listed below are maximum connector ratings defined by the IEC 60320 standard. Actual device, power supply, or circuit ratings may be lower.
C13 (female cable connector)
- Mates with: C14 inlet
- Rating: 10 A, 250 V AC
- Common use: Servers, storage systems, desktop PCs, monitors
C14 (male device inlet)
- Mates with: C13 connector
- Common use: Power supply inlets on IT equipment
C15 (female cable connector, high-temperature)
- Mates with: C16 inlet
- Temperature rating: Up to 120 °C
- Common use: Equipment with higher operating temperatures
C16 (male device inlet)
- Mates with: C15 connector
C19 (female cable connector)
- Mates with: C20 inlet
- Rating: 16 A, 250 V AC
- Common use: High-power servers, storage arrays, and PDUs
C20 (male device inlet)
- Mates with: C19 connector
Additional Information
- IEC 60320 connectors support AC mains voltages used globally (100–120 V and 200–240 V AC)
- Connector ratings do not override equipment power supply ratings, PDU limits, or facility electrical constraints
- DC-powered equipment uses different connector standards and is not covered by IEC 60320
- IEC 60320 - Wikipedia - images and additional information
- Comprehensive Guide to Global Power Cord Standards in Data Centers - images and additional information
