NetApp Knowledge Base
Understanding “init sensor invalid” state in environment sensor output
51
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • AFF/FAS/ASA series (including FAS27, FAS8300, A700s)
Issue
  • When running the environment sensor command with hidden sensors displayed, the output includes entries such as:
(system node environment sensors show -node * -hidden true -state !normal)
Node         Sensor   State    Value/Units
node1-nav    init     invalid
node2-nav    init     invalid
  • Normal sensor output does not show these entries unless the -hidden true parameter is used.
New to NetApp?
