NetApp Knowledge Base
Uncorrectable memory error on an AFF or FAS system with PPR
9,403
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
Platforms:
  • AFF A50, AFF A30, AFF A20, AFF C60, AFF C30, ASA A50, ASA A30, ASA A20, ASA C30, FAS50
  • AFF A1K, AFF A90, AFF A70, AFF C80, ASA A1K, ASA A90, ASA A70, FAS90, FAS70
  • AFF A900, ASA A900, FAS9500
  • AFF A800, AFF C800, ASA A800, ASA C800
  • AFF A700, FAS9000
  • AFF A700s
  • AFF A400, AFF C400, ASA A400, ASA C400, FAS8300, FAS8700
  • FAS2820
ONTAP Versions:
  • On systems with the BIOS version that include Post Package Repair capabilities, when a node panics or performs a power reset due to an uncorrectable memory error, a PPR memory diagnostic is initiated.
  • During this process, if PPR identifies a faulty memory segment, it will try to fix it. If this repair process is effective, there's no need for additional steps or component replacement.
  • This procedure describes how to check the results of a PPR test and determine what actions are needed.
New to NetApp?
