NetApp Knowledge Base
Temperature warning for Temperature sensor xx: not installed or failed
329
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS2650
  • DS224
Issue
Shelf module A (PCM A) issues a temperature warning regarding the unavailability of the shelf temperature
Example:
ENVIRONMENT
Temperature Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15; with error: none
Shelf temperatures by element:
[1] 23 C (73 F) (ambient)  Normal temperature range
[2] 24 C (75 F)  Normal temperature range
[3] 24 C (75 F)  Normal temperature range
[4] 24 C (75 F)  Normal temperature range
[5] 24 C (75 F)  Normal temperature range
[6] 25 C (77 F)  Normal temperature range
[7] 25 C (77 F)  Normal temperature range
[8] 24 C (75 F)  Normal temperature range
[9] 25 C (77 F)  Normal temperature range
[10] 28 C (82 F)  Normal temperature range
[11] Unavailable
[12] Unavailable
[13] 28 C (82 F)  Normal temperature range
[14] 37 C (98 F)  Normal temperature range
[15] 25 C (77 F)  Normal temperature range
EMS
5/15/2025 23:10:14  FAS2650-01      ALERT
ses.status.temperatureWarning: DS224-12 (S/N SHxxxxxxxxxxxxx) shelf 0 on channel 0b temperature warning for Temperature sensor 12: not installed or failed. Current temperature: 30 C (86 F). This module is on the rear of the shelf at the top left, on shelf module A.
5/15/2025 23:10:14  FAS2650-02      ALERT
ses.status.temperatureWarning: DS224-12 (S/N SHxxxxxxxxxxxxx) shelf 0 on channel 0a temperature warning for Temperature sensor 12: not installed or failed. Current temperature: 30 C (86 F). This module is on the rear of the shelf at the top left, on shelf module A.
5/15/2025 23:09:56  FAS2650-01      ALERT
ses.status.temperatureWarning: DS224-12 (S/N SHxxxxxxxxxxxxx) shelf 0 on channel 0b temperature warning for Temperature sensor 11: not installed or failed. Current temperature: 48 C (118 F). This module is on the rear of the shelf at the top left, on shelf module A.
5/15/2025 23:09:56  FAS2650-02      ALERT
ses.status.temperatureWarning: DS224-12 (S/N SHxxxxxxxxxxxxx) shelf 0 on channel 0a temperature warning for Temperature sensor 11: not installed or failed. Current temperature: 48 C (118 F). This module is on the rear of the shelf at the top left, on shelf module A.
New to NetApp?
