NetApp Knowledge Base
SP not reachable for every other node when running system node power show command
604
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9.8 and earlier
Issue
  • When connecting to the cluster_mgmt LIF, the following errors are reported for all other nodes:
::> system node power show
Error: The Service Processor on node "nodeB" is not reachable. Verify that the SP or BMC is online, verify that api-service is enabled on the SP or
BMC, verify that the partner node is running, check if pings from SP or BMC to partner node work, check if hw-assist keep-alives are normal,
check that network ports are configured correctly and are functional (up). Then, try the command again.
nodeB -
  • The node hosting the cluster_mgmt LIF reports the output
nodeA on
  • When connecting to another node via management LIF the problem is not seen and the output is returned from all nodes
New to NetApp?
