NetApp Knowledge Base
SAS Expander has set the Chassis LED ON remains after PSU replacement even if reboot BMC
452
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS2720
  • Baseboard Management Controller(BMC)
Issue
  • Chassis attention LED remains on after PSU replacement:
get_leds
FRU LEDs status
FRU LED ID 1  = BMC Locate LED
FRU LED ID 2  = BMC System LED
FRU LED ID 3  = BMC Controller Attention LED
FRU LED ID 4  = BMC Controller Active LED
FRU LED ID 1 is off
FRU LED ID 2 is on. Set by Expander
FRU LED ID 3 is off
FRU LED ID 4 is on
  • PSU looks good after replacement:
/usr/local/bin/environ -show_all
Sensor Name              State          Current    Critical     Warning     Warning    Critical
Reading       Low         Low         High       High
PSU2 Bad                                 FALSE
PSU1 Bad                                 FALSE
PSU2                                      GOOD
PSU1                                      GOOD
PSU2 ON                                     ON
PSU1 ON                                     ON
PSU1 INFO                               FRU_AVAIL
PSU1 INFO                               FRU_AVAIL
PSU1 FRU                                  GOOD
PSU2 FRU                                  GOOD
  • Service event shows both nodes set chassis LED on:
Node             ID  Event Location                      Event Description
Node-01           1   Chassis 1                           SAS Expander has set the Chassis LED ON
Node-02           1   Chassis 1                           SAS Expander has set the Chassis LED ON
  • System health subsystem shows no fault:
Subsystem         Health
SAS-connect       ok
Environment       ok
Memory            ok
Service-Processor ok
Switch-Health     ok
CIFS-NDO          ok
Motherboard       ok
IO                ok
MetroCluster      ok
MetroCluster_Node ok
FHM-Switch        ok
FHM-Bridge        ok
SAS-connect_Cluster ok
  • Even if delete the service event then reboot BMC, or manually set the led off,  issue persists, and the service event raised again.
New to NetApp?
