NetApp Knowledge Base
Personality for UTA or CNA port not automatically set after a motherboard replacement for FAS or AFF models
823
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • AFF Models
  • FAS Models
  • ONTAP 9
Issue
  • Typically when a motherboard replacement procedure occurs, the personality of the UTA/CNA ports on the motherboard are carried forward to the new motherboard.  During boot the following message is seen:
A system reboot is required to apply personality changes for onboard UTA2 (CNA) ports.
  • After the system is rebooted, the personality of the UTA/CNA ports will be set the same as they were on the previous controller.  The controller will automatically enter maintenance mode to continue with post replacement procedures.
  • When this automatic process does not work as expected, the system will continue to boot with default mode setting (which varies by platform) for each onboard UTA/CNA port regardless if that was the previous settings of the impaired motherboard.
New to NetApp?
