PCIE Device B1/0/0 (SLOT-3) is not link up, then x times warm reboot for recovery
Applies to
- C400
- ONTAP 9.16.1P4
Issue
- Upon powering on the storage node, the 10G Base-T Ethernet NIC card located in slot 3 is only recognized after failing to be detected four times
Example:
BIOS Version: 16.10PEI start.CPU PEI initialization.Wait BMC self-test result.BMC self-test: OK.UPI initialization.CPU initialization.Running full memory initialization.SPI FLASH: Primary BIOSPEI end.DXE start.USB initialization.PCI host bridge initialization.CSM initialization.PCI Bus initialization start.PCIE Device B1/0/0 (slot-3) is not link up, then 1 times warm reboot for recovery.BIOS Version: 16.10PEI start.CPU PEI initialization.Wait BMC self-test result.BMC self-test: OK.UPI initialization.CPU initialization.Running full memory initialization.SPI FLASH: Primary BIOSPEI end.DXE start.USB initialization.PCI host bridge initialization.CSM initialization.PCI Bus initialization start.PCIE Device B1/0/0 (slot-3) is not link up, then 2 times warm reboot for recovery.BIOS Version: 16.10PEI start.CPU PEI initialization.Wait BMC self-test result.BMC self-test: OK.UPI initialization.CPU initialization.Running full memory initialization.SPI FLASH: Primary BIOSPEI end.DXE start.USB initialization.PCI host bridge initialization.CSM initialization.PCI Bus initialization start.PCIE Device B1/0/0 (slot-3) is not link up, then 3 times warm reboot for recovery.BIOS Version: 16.10PEI start.CPU PEI initialization.Wait BMC self-test result.BMC self-test: OK.UPI initialization.CPU initialization.Running full memory initialization.SPI FLASH: Primary BIOSPEI end.DXE start.USB initialization.PCI host bridge initialization.CSM initialization.PCI Bus initialization start.PCIE Device B1/0/0 (slot-3) can not recovery after 3 times warm reset continue boot.BDS start.Console output devices connect.- Reseating the NIC card from slot 3 does not resolve the issue
- Moving the NIC card from slot 3 to slot 2 fails to resolve the issue
- After returning the NIC card back to slot 3, a recovery procedure is still required for proper detection
- After rebooting ONTAP, the issue is cleared
