'Onboard: Quad Port 12G SAS' not shows up in sldiag test output and test system and stress test menu
Applies to
- FAS8300
- AFF-A400
- ONTAP prior to 9.13.1
Issue
- With SAS connect between Port 0a-0c,0b-0d.
sldiagoutput not including "Onboard: Quad Port 12G SAS":
Setting LAN IP Address to 192.xxx.xxx.xxx
Setting LAN Subnet Mask to 255.255.255.0
Copyright (c) 2019 NetApp Inc. All rights reserved.
FAS8300 System-Level HW Diagnostics 04.05.09
#### System PN: xxx-xxxxx ####
#### System SN: xxxxxxxxxxxx ####
#### Controller-B PN: xxx-xxxxx ####
#### Controller-B SN: xxxxxxxxxxxx ####
1) Scan System
2) Test System (must scan system, first)
3) Test Memory (must scan system, first)
4) Stress-Test System (must scan system, first)
5) Show VPD Information
6) Show FW Revision
7) Show MAC Address
8) Show Logs
9) Reboot (BMC Power Cycle) Controller to LOADER
Select a number 1-9 to execute the respective command: 1
System Scan Start: 2023-01-23 00:27:55
BMC:
Device ID Device Rev. FW Rev. IPMI Ver. Device Available
32 1 13.07 2.0 yes
Onboard: Dual Port 25GbE RoCE NIC:
Interface Link Speed FW Version
e0a Up 25000Mb/s 16.26.4012 (NAP0000000006)
e0b Up 25000Mb/s 16.26.4012 (NAP0000000006)
Onboard: Dual Port 100GbE RoCE NIC:
e0c Up 100000Mb/s 16.26.4012 (NAP0000000005)
e0d Up 100000Mb/s 16.26.4012 (NAP0000000005)
Onboard: Quad Port 12G SAS" also not shows up inTest SystemandStress-Test:
+--------------------------------Test System-----------------------------------+
| Select one or more items to test using the SPACE bar to toggle the option. |
| Use Arrow keys to move up/down to select invidiual test. Use Arrow keys |
| left/right to select Test Control. Press [Enter] to execut. |
| |[ ] a. CPU Test (Register read test) | |
| |[ ] b. TPM Test (Self-test) | |
| |[ ] c. Ethernet I210 Test (Internal loopback test) | |
| |[ ] d. BMC Test (Self-test/Sensor status chec| |
| |[ ] e. PSU Test (Sensor status check) | |
| |[ ] f. PCH-I2C Test (Device read test) | |
| |[ ] g. Fan Test (Fan speed control test) | |
| |[ ] h. Onboard: Dual Port 25GbE RoCE NIC Test(BIST/External loopback test)| |
| |[ ] i. Onboard: Dual Port 100GbE RoCE NIC Tes(BIST/External loopback test)| |
| |[ ] j. Mezz: Quad Port 25GbE RoCE NIC Test (BIST/External loopback test)| |
| |[ ] k. HBA: Dual Port 10GbE NIC Test (BIST/External loopback test | |
| |[ ] l. HBA: Dual Port 10GbE NIC Test (BIST/External loopback test | |
< OK ><Test all>< Cancel >a(Register read test)
+-----------------------------Stress Test System-------------------------------+
| left/right to select Test Control. Press [Enter] to execut |
| |[ ] a. CPU Stress (CPU stress) | |
| |[ ] b. Memory Stress (Random pattern test) | |
| |[ ] c. M.2 SATA Drive Stress (Read operation test) | |
| |[ ] d. M.2 NVMe Drive Stress (Read operation test) | |
| |[ ] e. Onboard: Dual Port 25GbE RoCE NIC Stress (External loopback test)| |
| |[ ] f. Onboard: Dual Port 100GbE RoCE NIC Stress (External loopback test)| |
| |[ ] g. Mezz: Quad Port 25GbE RoCE NIC Stress (External loopback test)| |
| |[ ] h. HBA: Dual Port 10GbE NIC Stress (External loopback test)| |
| |[ ] i. HBA: Dual Port 10GbE NIC Stress (External loopback test)| |
< OK ><Test all>< Cancel ><><><><>Press [Enter] key to go back to Main Menu
- All SAS ports are functional, either from the loader or after boot when checking status.
