NetApp Knowledge Base
Node reboot for no disks attached after TPM FW upgrade during MB replacement
141
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS/AFF
  • Motherboard replacement
  • TPM firmware lower than 5.63
Issue
  • When replacing a motherboard, the node was booted into ONTAP and CFO giveback was performed in order to update TPM firmware to 5.63 as in How to upgrade TPM firmware
  • After updating the TPM firmware to 5.63 using this process, the node cannot boot to ONTAP
  • Node is in a boot loop for no disks attached, while the disks are attached and visible
New to NetApp?
