NetApp Knowledge Base
NVDIMM Temperature not readable in AFF A900 due to NVRAM module
190
Visibility:
Votes:
0
Category:
not set
Specialty:
HW
Last Updated:
This knowledge base was generated through a script and may contain formatting issues. For the accurate content, please refer to the WIP editor. WIP editor.
Applies to
  • AFF A900
  • NVRAM module
Issue
Node was continuously triggering the temperature sensor unreadable errors on NVDIMMs.
  • CONSOLE-LOGS (During the boot process)
node1:monitor.temp.unreadable:error]: The controller temperature (PM40068B Temp) is not readable.
node1:monitor.temp.unreadable:error]: The controller temperature (FPGA Temp 0) is not readable.
node1:monitor.temp.unreadable:error]: The controller temperature (FPGA Temp 1) is not readable.
node1:monitor.temp.unreadable:error]: The controller temperature (NV M.2 Temp) is not readable.
node1:monitor.temp.unreadable:error]: The controller temperature (NVDIMM 1 Temp) is not readable.
node1:monitor.temp.unreadable:error]: The controller temperature (NVDIMM 2 Temp) is not readable.
  • Environment-Sensor
         PM40068B Temp         not-available - C          0        1      95     1
         VBAT P8V              not-available - mV      7000     7400    8550    89
         HS VOUT               not-available - mV     10560    11160   12840   134
         HS Current            not-available - mA         0     1000   14000   150
         NV DIMM1 CECC Count   not-available - cycles     -        -       -
         NV DIMM2 CECC Count   not-available - cycles     -        -
  • BMC-LOGS (bmc status -d)
​​cat /mnt/logs/frumsgs
node1 fru_mond[1044]: [ERROR]Start locater is incorrect 0xffffffff
node1 fru_mond[1044]: [ERROR]Platform VPD Header is corrupted on fru NVS
node1 fru_mond[1044]: [ERROR]Could not read platform vpd header information
New to NetApp?
