NS224 shelf led turns on and off repeatedly due to cooling fan error
Applies to
Issue
- On an NS224 shelf, the
!LED indicator turns on and off repeatedly due to cooling fan error:
Sep 27 07:19:04 [node_name:ses.status.fanError:EMERGENCY]: NS224NSM100 (S/N XXXX) shelf 0 on channel 0x cooling fan error for Cooling element 12: critical status. This element is on the unknown location.
Sep 27 09:43:25 [node_name:ses.status.fanError:EMERGENCY]: NS224NSM100 (S/N XXXX) shelf 0 on channel 0x cooling fan error for Cooling element 17: critical status. This element is on the unknown location.
STORAGE-SHELF.XMLshows physical locations from AutoSupport:
| Error Text |
Fan "12" is running below normal RPM threshold. Fan is located in the inlet FAN of fan module 2 in the bottom shelf module (B). |
| Corrective Action |
Verify that the fan module is fully seated and secured (fan is integrated into the power supply module in some disk shelves). If the problem persists, replace the fan |
