NetApp Knowledge Base
Fault LED on and PCM status shows as 'PC SHELF FAULT RQSTD'
3,679
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2500 series
  • FAS2600 series
  • FAS2700 series
  • FAS2200 series
  • AFF A200
Issue
  • The fault LED of the controller is on.
  • storage show fault -v displays the following:
Enclosure:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,02,00   FAIL
Vendor Unique Element 88-IOM6E: (PCM)
  1: OK                01,01,00,00
  2: OK                01,01,00,80   PC SHELF FAULT RQSTD
This can be accompanied by:
  • EMS reports frequent reboots and multiple sensor errors
Sun Aug 08 01:48:43 0000 [Node1: dsa_worker3: ses.status.ACPError:alert]: DS4246 (S/N xxx shelf 0 on channel 0a ACP Processor error for SAS shelf ACP processor 1: critical status ; Alternate Control Path hardware failed This module is on the rear of the shelf at the top center, on shelf module A.
Sun Aug 08 01:48:52 0000 [Node1: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
Sun Aug 08 01:49:00 0000 [Node1: monitor: monitor.globalStatus.critical:EMERGENCY]: Disk shelf fault.
Sun Aug 08 02:00:00 0000 [Node1: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
Sun Aug 08 02:35:01 0000 [Node1: spsm_listener: sp.update.status:debug]: params: {'reason': 'sp_startup_notify_servprocd: SP startup handler has been called. '}
Sun Aug 08 02:35:04 0000 [Node1: splog_main: splog.running.normally:info]: Process splogd is operating normally.
Sun Aug 08 02:35:22 0000 [Node1: dsa_worker1: ses.status.ACPInfo:info]: DS4246 (S/N xxx) shelf 0 on channel 0a ACP Processor information for SAS shelf ACP processor 1: normal status.
  • Rebooting SP due to loss of ACP communications
Record 2773:Sun Aug 8 02:33:15 2021 [SP.critical]: Rebooting SP due to loss of ACP comms
Record2774:Thu Jan 1 00:00:37 1970 [IPMI.notice]: 2902 | c0 | OEM: ffff70005100 | ManufId: 150300 | SP Reset Internally
Record 2775:Thu Jan 1 00:00:42 1970 [IPMI.notice]: 2a02 | 02 | EVT: 0301ffff | Power_Good | Assertion Event, "State Asserted"
Record 2776:Thu Jan 1 00:00:43 1970 [IPMI.notice]: 2b02 | 02 | EVT: 0301ffff | Power_Proc_OK | Assertion Event, "State Asserted"
Record 2777:Thu Jan 1 00:00:44 1970 [IPMI.notice]: 2c02 | 02 | EVT: 0301ffff | Controller_Fault | Assertion Event, "State Asserted"
Record 2778: Thu Jan 1 00:01:00 1970 [SP.notice]: Running primary version 2.11
Record 2779:Thu Jan 1 00:01:03 1970 [SP.normal]: Heartbeat started
New to NetApp?
