Is BMC reconfiguration or BMC firmware update required after management module replacement
Applies to
- Management Module: X50192A
- AFF and ASA A70
- AFF and ASA A90
- AFF and ASA A1K
- AFF C80
- FAS70
- FAS90
- Baseboard Management Controller (BMC)
Answer
No, it is not usually required.
- BMC firmware is bundled with ONTAP and is automatically checked and updated during ONTAP boot.
- If the BMC firmware was manually upgraded to a version newer than the ONTAP-bundled version, a separate firmware update may be required after the replacement.
- When ONTAP is operating normally, BMC settings are synchronized with ONTAP.
- Therefore, BMC reconfiguration is typically not required after replacing the management module.
