How do four PSUs power controller in A800 or C800?
Applies to
- AFF A800, AFF C800
- ASA A800, ASA C800
Answer
- This platform has 4x total PSUs per system.
- PSUs are plugged directly into the Processor Controller Module (PCM) (2 per canister).
- PSUs power the midplane and if a failure occurs, will also power the partner PCM.
- 2+2 configuration
- Require power to at least 2 PSUs at all times for proper system operation.
- The Platforms will remain operational with up to 2 PSU failures.
- More than 2 will initiate a Takeover to the Partner or will shutdown on a Single node cluster.
- Power from each PSU is delivered throughout the system (midplane, fans, partner PCM, local PCM).
Additional Information
additionalInformation_text
