NetApp Knowledge Base
Fault LED on with PCM status shows as SP SHELF FAULT RQSTD
92
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • FAS2720
  • ONTAP 9.9.1P15
Issue
  • Controller fault LED on
  • storage show fault -v outputs
Node: node-01
Enclosure Status: normal
Channel: 0a
Shelf: 0
Shelf Type: DS212-12
Product Serial Number: SHFNC21xxxxxxxx
Module Type: IOM12E
Enclosure:
Element Status         Status Bytes  Status Descriptions
1: OK                01,00,02,00   FAIL
Vendor Unique Element 88-IOM12E: (PCM)
1: OK                01,01,00,00
2: OK                01,01,80,00   SP SHELF FAULT RQSTD
Node: node-02
Channel: 0a
Shelf: 0
Module Type: IOM12E
Enclosure:
1: OK                01,01,00,00
  • There are no errors related to the shelf in the EMS log
New to NetApp?
