NetApp Knowledge Base
FAS2820 Controller fault LED ON and PCIe card link width mismatch
169
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2820
  • ONTAP 9
Issue
  • Controller fault LED ON.
  • In the SP-LATEST-RUNTIME log, ID 13 LED  is on.
tag  origin  fld                                 fault reason                 count  time
1    bios    /chassis-1/controller-a/pcie-2     - Expected x4, actual x1      1      Sun Aug 24 14:43:26 2025
Fault Lights On:
             /chassis-1                                                       1
             /chassis-1/controller-a                                          1
             /chassis-1/controller-a/pcie-2                                   1
FRU LEDs status
FRU LED ID 1    Controller Locate LED
FRU LED ID 2    System Attention LED
FRU LED ID 3    Controller Attention LED
FRU LED ID 4    Controller Active LED
FRU LED ID 13    NVME 1 Attention LED
led 1 is off
led 2 is on
led 3 is on
led 4 is on
led 13 is on
  • pcie.stealth.link.errors is seen in EMS log:
[Node01:PCILink:pcie.stealth.link.errors:debug]:params:{'pcie_link_errors':'performance is not optimal for Intel Dual 10G NIC in slot1... LinkStatus(LkSp(3),LkWd(1),SClk,DLAct).'}
  • SP-LATEST-SYSTEM-EVENT-LOG reports following events:
Record 376: Sun Aug 24 14:43:27.000000 2025 [SysFW.notice]: Device 3/0/0 (MEZZ Dev 2) failed to retrain at max link width
Record 377: Sun Aug 24 14:43:27.000000 2025 [SysFW.notice]:  - Expected x4, actual x1
  • PCI-HIERARCHY.XML
1 Br[18a8](0,16,0): PCI Device 8086:18a8 on Controller LinkCap(MaxLkSp(3),MaxLkWd(8),ASPM(0),L0(4),L1(4),SurpDn,DLAct,Port(16)) LinkStatus(LkSp(3),LkWd(1),SClk,DLAct),
2 Dv[1563](3,0,0) in slot 1: Intel Dual 10G NIC in slot 1 on Controller LinkCap(MaxLkSp(3),MaxLkWd(4),ASPM(3),L0(5),L1(4),Port(0)) LinkStatus(LkSp(3),LkWd(1),SClk),
New to NetApp?
