NetApp Knowledge Base
FANs go high and HA Group Notification (SHELF_FAULT) ERROR intermitently on FAS25xx
1,461
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS25xx
  • Alternate control path (ACP)
  • ONTAP 9
Issue
  • System FANs go intermitently to high speed
  • Autosupport alerts of:
  • EMS
[node-01: dsa_worker3: ses.status.ACPError:alert]: DS2126 (S/N SHJHU1642000123) shelf 0 on channel 0a ACP Processor error for SAS shelf ACP processor 2: critical status    ; Alternate Control Path hardware failed This module is on the rear of the shelf at the top right, on shelf module B.
[node-01: monitor: monitor.globalStatus.critical:EMERGENCY]: Disk shelf fault.
[node-01: statd: monitor.shelf.fault:alert]: Critical fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[node-01: statd: callhome.shlf.fault:error]: Call home for SHELF_FAULT
  • STORAGE-FAULT
Enclosure:
Element Status         Status Bytes  Status Descriptions
  1: OK                01,00,02,00   FAIL
Vendor Unique Element 85-IOM6E: (ACP)
  1 [IOM6E A]    : OK                01,10,00,00   INBACP
  2 [IOM6E B]    : CRITICAL          02,10,00,40   INBACP, FAIL
Vendor Unique Element 88-IOM6E: (PCM)
  1: OK                01,01,00,00
  2: OK                01,01,00,80   PC SHELF FAULT RQSTD
  • SYSCONFIG-A
node-01
System ACP Connectivity: Inband Active
node-02
System ACP Connectivity: Full Connectivity
  • STORAGE-ACP.XML
node-01
Channel    in-band
node-02
Channel    out-of-band
  • Issue remains after rebooting the SP (Service Processor)
  • Issue remains after disabling and re-enabling the ACP (Alternate Control Path)
New to NetApp?
