Excessive connects and disconnects due to glitch in IC network, causing system panic
Applies to
ONTAP 9.7
Issue
In an ONTAP environment where clusters with multiple nodes are peered with many other clusters, and all the inter-cluster connections in a node are closed and re-established at the same time, the system might encounter disruption while processing the new connections.
