NetApp Knowledge Base
EMULEX Adapter Showing a "?" in Switch Port Field After SFP Replacement
703
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
san
Last Updated:
Applies to
  • Emulex XE501
  • Emulex FC Adapters
Issue
  • Post SFP replacement or hardware swap, the adapter is stuck in a hung state and does not allow connection despite being Online/UP.
  • This can appear as a ? in the Switch Port field for initiator ports:
slot 1: FC Host Adapter 1a (Emulex XE501 rev. 1, N-port, <UP>)
		Board name:        111-03648
		Serial Number:     1111111111
		Firmware rev:      11.4.277.0
		Host Port Id:      0x30b00
		FC Node Name:      1:000:101010:111000
		FC Port Name:      1:000:010101:000111
		SFP Vendor:        FINISAR CORP.
		SFP Part Number:   FTLF8532P4BCV-N1
		SFP Serial Number: P65ALNP
		SFP Capabilities:  8, 16 or 32 Gbit
		Link Data Rate:    32 Gbit
		Switch Port:       ?
  • Also can manifest as half of the adapter's information fields showing as blank in Autosupports when reviewing FCP Adapters.
New to NetApp?
