Disks using DS4486 shelf fail on ONTAP 9.8
Applies to
- DS4486 Disk Shelf
- ONTAP 9.8
Issue
- Disks in the DS4486 shelf fail upon upgrade to 9.8 and may also be seen to fail without cause following a takeover and giveback on the affected version:
Fri Jul 30 12:25:12 +0000 [node03: api_dpool_25: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.15L1 (S/N 7PH8MKMG) error 40000000h
Fri Jul 30 12:25:12 +0000 [node03: api_dpool_26: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.5L1 (S/N 7PH8LSNG) error 40000000h
Fri Jul 30 12:25:12 +0000 [node03: api_dpool_27: scsi.debug:debug]: shm_setup_for_failure disk 11d.08.22L1 (S/N 7PGSVKZG) error 40000000hFri Jul 30 12:46:08 +0000 [node03: api_dpool_10: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.15L1(S/N 7PGRY6XG) error 40000000h
Fri Jul 30 12:46:08 +0000 [node03: api_dpool_11: scsi.debug:debug]: shm_setup_for_failure disk 11d.07.5L1 (S/N 7PGP6BTG) error 40000000h
Fri Jul 30 12:46:08 +0000 [node03: api_dpool_12: scsi.debug:debug]: shm_setup_for_failure disk 11d.08.22L1 (S/N 7PH8MLNG) error 40000000h
