NetApp Knowledge Base
Device PCI NTB for HA not detected on PCI BUS
1,201
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2720
  • AFF A150
Issue
Node boot failed, run into loader prompt with PCIe device missing error:
LOADER-B> boot_ontap
---<<BOOT>>---
NetApp Data ONTAP 9.9.1
Device ("PCI NTB for HA" ) not detected on PCI BUS.
Device could be purposely held in reset or has developed a physical defect
or has a corrupt firmware.
Halting the system because the device is critical for normal operations.
Bootarg no-onboard-pcidev-check? can skip this check.
Halting...
BIOS Version: 11.11
Portions Copyright (C) 2014-2021 NetApp, Inc. All Rights Reserved.
Initializing System Memory ...
Loading Device Drivers ...
Configuring Devices ...
BIOS POST Failure(s) detected: PCIe device missing error detected. Abort AUTOBOOT
New to NetApp?
