NetApp Knowledge Base
DS212C EMS Log Report: Cooling Fan and Temperature Sensor Not Installed Warning
159
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • DS212C shelf
  • Systems with internal DS212C shelf
Issue
  • The shelf front warning LED is blinking.
  • EMS Log shows  Cooling Fan and Temperature Sensor Not Installed Warning.
[ses.status.fanWarning:notice]: DS212-12 (S/N *****) shelf 1 on channel 0b cooling fan warning for Cooling element 1: not installed. This module is on the rear of the shelf on the lower left power supply.
[callhome.shelf.fan.warn:error]: Call home for SHELF COOLING UNIT FAILED
[ses.status.temperatureWarning:alert]: DS212-12 (S/N ****) shelf 1 on channel 0b temperature warning for Temperature sensor 6: not installed. Current temperature:  C ( F). This module is on the rear of the shelf on the lower left power supply.
  • ENVIRONMENT log shows multiple sensors are Unavailable.
Channel: 0a
    Shelf: 1
    SES device path: local access: 0b.01.99
    Module type: IOM12B; monitoring is active
    Shelf status: normal condition
    SES Configuration, shelf 1:
     logical identifier=****
     vendor identification=NETAPP
     product identification=DS212-12
     product revision level=0141
Power Supply installed element list: 2; with error: none
    Power Supply information by element:
      [1] Serial number: <N/A>  Part number: <N/A>
          Type: <N/A>
          Input voltage: <N/A>
          Firmware version: <N/A>  Swaps: 0
      [2] Serial number: PST094242221387  Part number: 114-00148+G2
          Type: 98
          Firmware version: 0200  Swaps: 0
    Voltage Sensor installed element list: 3, 4; with error: none
    Shelf voltages by element:
      [1] Unavailable
      [2] Unavailable
      [3] 5.01 Volts  Normal voltage range
      [4] 12.02 Volts  Normal voltage range
    Current Sensor installed element list: 3, 4; with error: none
    Shelf currents by element:
      [1] Unavailable
      [2] Unavailable
      [3] 2260 mA  Normal current range
      [4] 3240 mA  Normal current range
    Cooling Unit installed element list: 3, 4; with error: none
    Cooling Units by element:
      [1] Unavailable
      [2] Unavailable
      [3] 7020 RPM
      [4] 7050 RPM
  • Despite rebooting the BMC, replacing the PSU, and reseating the IOM, the shelf PSU alert persists.
New to NetApp?
