Current cluster configuration is not supported. Reason: MetroCluster with Fibre Channel (FC) is not supported
Applies to
- Ontap 9
- MetroCluster
Issue
When setting up a re-purposed cluster, you receive the following error when trying to create an aggregate:
The current cluster configuration is not supported. Reason: MetroCluster with Fibre Channel (FC) is not supported.
