NetApp Knowledge Base
Cluster switches not being monitored due to routing issues between nodes and switches
107
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS/AFF Systems
  • Cluster Network Switches
Issue
  • The cluster switches are not being monitored for the below reason:
Cluster1::> system switch ethernet show
Switch                      Type               Address          Model
Cluster1-SW1                cluster-network    194.1.2.34       CN1610
     Serial Number: 40XXXXXXXXX
      Is Monitored: false
            Reason: IP address reachable
  Software Version: 1.3.0.3
    Version Source: ISDP
  • Adding the cluster switch to monitoring fails with the below error:
Cluster1::> system switch ethernet create -device Cluster1-SW1 -address 194.1.2.34 -snmp-version SNMPv2c -community cshm1! -model CN1610 -type cluster-network -is-monitoring-enabled-admin true
Error: IP address is not reachable. Verify that the "-address" value is valid or check the network path.
New to NetApp?
