NetApp Knowledge Base
"Chassis temperature is too warm: CPU0 Temp Margin is critical high (0 C)." alert
2,545
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS8200
  • AFF A300
  • Service Processor (SP) firmware 5.7 and earlier
Issue
  • The system reports a critical high temperature for CPU0 but reading is 0:
Thu Apr 09 02:29:55 BST [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: CPU0 Temp Margin is critical high (0 C).
Thu Apr 09 02:30:00 BST [node_name: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
Thu Apr 09 02:30:55 BST [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
Wed Apr 15 13:36:58 BST [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: CPU0 Temp Margin is critical high (0 C).
Wed Apr 15 13:37:42 BST [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
  • The environmental platform sensors output is :
Chassis Thermal Zone discrete fault    normal OVER_TEMP
Temp Average High  discrete fault    normal YES
CPU0 Temp Avg   thermal  crit-high 0 C
CPU0 Temp Margin  thermal  crit-high 0 C
Is Board Over Temp  discrete fault    normal OVER_TEMP
New to NetApp?
