NetApp Knowledge Base
Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV)
388
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • FAS2720
  • FAS2750
Issue
FAS2720/FAS2750 show lots of Chassis power alert.
EMS log :
Wed May 03 01:03:39 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 02:03:41 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 03:03:42 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 03:31:32 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 04:31:33 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 05:31:34 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 06:31:35 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 07:31:36 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 08:31:36 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 09:31:38 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 10:31:39 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 10:54:39 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
New to NetApp?
