NetApp Knowledge Base
Cable attached to SAS port x is functioning in a degraded mode
5,696
Visibility:
Votes:
1
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • SAS storage shelves
  • System is cabled Multipath-HA
Issue
  • ONTAP Event Message System example:
[sas.cable.degraded:warning]: Cable attached to SAS port "0b" is functioning in a degraded mode
  • ONTAP event log show output example:
::> event log show -event sas.cable*
Time Node      Severity Event
...  node_name ERROR    sas.cable.degraded: Cable attached to SAS port "0a" is functioning in a degraded
  • ONTAP system health degraded example:
::> system health subsystem show
Subsystem         Health
SAS-connect       degraded
Environment       ok
SAS-connect_Cluster ok
13 entries were displayed.
  • The speed of some PHYs is reduced/disabled/rate unknown when checked from ONTAP CLI sysconfig -a output. Example:
::> system node run -node <node_name> -command sysconfig -a
slot 0: SAS Host Adapter 0a (PMC-Sierra PM8072 rev. C, SAS, <UP>)
    Firmware rev:       03.08.09.00
    Base WWN:           5:00a098:00e1428:a4
    Temperature:        Not Available
    Phy State:          [8] Enabled, 12.0 Gb/s
                        [9] Enabled, 6.0 Gb/s
                        [10] Enabled, 6.0 Gb/s
                        [11] Enabled, 12.0 Gb/s
or
    Base WWN:           5:00a098:00f46d8:30
    Phy State:          [0] Disabled
                        [1] Disabled
                        [2] Enabled, Rate unknown
                        [3] Enabled, 12.0 Gb/s
  • The issue remains with a new SAS cable
  • The issue remains with a new shelf IOM module, where that SAS cable is connected to.
New to NetApp?
