NetApp Knowledge Base
CHASSIS POWER SUPPLY DEGRADED ERROR event after PSU replacement in ONTAP 9
1,747
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
Applies to
  • AFF-A400
  • PSU (power supply unit)
Issue
  • After a failed PSU is replaced, the autosupport  CHASSIS POWER SUPPLY DEGRADED ERROR is still generated
  • Platform sensors report the PSU is bad
PSU2 State    discrete    fault            normal    BAD
  • The errors on the new PSU are different from the first PSU
From PLATFORM-SENSORS.XML:
  • Original PSU prior to replacement
PSU2 FRU Switch    discrete    normal            normal    ON
PSU2 FRU Power    discrete    fault            normal    LOW
PSU2 FRU Current    discrete    fault            normal    LOW
PSU2 FRU Voltage    discrete    fault            normal    LOW
PSU2 FRU Temp    discrete    normal            normal    OK
PSU2 VIN    voltage    normal    204880    mV            90480    93600    261040    263120
PSU2 VOUT    voltage    crit-low    0    mV            11336    11440    12948    13156
PSU2 Curr IIN    current    normal    936    mA            0        9984    12012
PSU2 IOUT    current    crit-low    0    mA            0        130000    132000
PSU2 PIN    unknown    crit-low    0    W            7    14    1611    1796
PSU2 POUT    unknown    crit-low    0    W            7    14    1611    1796
PSU2 Inlet    thermal    normal    25    C            0        58    63
PSU2 Hot    thermal    normal    36    C            0        100    105
PSU2 FB Hot    thermal    normal    32    C            0        100    105
PSU2 FAN    fan    normal    1500    RPM            800    1200
  • New PSU installed
PSU2 FRU Power    discrete    normal            normal    OK
PSU2 FRU Current    discrete    normal            normal    OK
PSU2 FRU Voltage    discrete    normal            normal    OK
PSU2 FRU Temp    discrete    fault            normal    LOW
PSU2 VOUT    voltage    normal    12012    mV            11336    11440    12948    13156
PSU2 Curr IIN    current    normal    884    mA            0        9984    12012
PSU2 IOUT    current    normal    13000    mA            0        130000    132000
PSU2 PIN    unknown    normal    170    W            7    14    1611    1796
PSU2 POUT    unknown    normal    163    W            7    14    1611    1796
PSU2 Inlet    thermal    normal    26    C            0        58    63
PSU2 FB Hot    thermal    crit-low    0    C            0        100    105
PSU2 FAN    fan    normal    4600    RPM            800    1200
New to NetApp?
