NetApp Knowledge Base
CHASSIS FAN FRU FAILED: Multiple fans have failed due to high traffic from intercluster LIFs
1,216
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
Applies to
  • ONTAP 9
  • FAS 26xx series
  • FAS 27xx series
Issue
  • One node in HA pair reports issues with reading temperature sensors which get corrected automatically:
[node1: env_mgr: monitor.fan.warning:notice]: multiple fans have failed. Replace it to avoid overheating
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module B Expander Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Module A Expander Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 4 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 3 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 2 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Midplane 1 Temp) is not readable.
[node1: env_mgr: monitor.temp.unreadable:error]: The controller temperature (Ambient Temp) is not readable.
[node1: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Multiple fans have failed
[node1: env_mgr: monitor.fan.ok:notice]: All fans are OK.
[node1: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
[node1: monitor: monitor.globalStatus.ok:notice]: The system's global status is normal.
  • Certain temperature sensors go unavailable on the affected node whereas the partner node reports them as normal.
cluster1::> system node run -node * -command environment status
2 entries were acted on.
Node: node1
        Shelf temperatures by element:
          [10] 28 C (82 F)  Normal temperature range
          [11] Unavailable
          [12] Unavailable
          [13] 29 C (84 F)  Normal temperature range
Node: node2
          [10] 33 C (91 F)  Normal temperature range
          [11] 48 C (118 F)  Normal temperature range
          [12] 26 C (78 F)  Normal temperature range
          [13] 34 C (93 F)  Normal temperature range
  • The FRU status is seen degraded when the issue is active but only from one node:
cluster1::> system controller fru show
Node               FRU Name                     Subsystem          Status
node1              PSU1 FRU                     Environment        degraded
node1              PSU2 FRU                     Environment        degraded
node2              PSU1 FRU                     Environment        ok
node2              PSU2 FRU                     Environment        ok
  • The BMC of the affected node reboots frequently and reports the following in the SP event logs:
Record 1250: Sat Jan 28 10:04:27.990616 2023 [BMC.critical]: Rebooting SP due to loss of ACP comms
Record 1251: Sun Jan 01 00:00:23.962645 2017 [IPMI.notice]: 00fd | c0 | OEM: ffff70005100 | ManufId: 150300 | BMC Reset Internally
  • Packet trace analysis on port e0M during issue time reveals high incoming traffic from the intercluster logical interface (IC LIF).
New to NetApp?
