NetApp Knowledge Base
Both the nodes are indicating Chassis power supply x is degraded: PSUx sensorName is Unreadable
325
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
Applies to
FAS8200
Issue
  • Both the nodes are indicating Chassis power supply x is degraded: PSUx sensor_name is Unreadable
  • PSU FRU Power is OFF
Example:
node-a
EMS
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Temperature is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Current is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan1 Speed is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan1 Fault is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan2 Speed is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan2 Fault is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Pwr Out OK is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fault is Unreadable
[?]  Mon Jul 29 13:07:07  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Over Temp is Unreadable
[?]  Mon Jul 29 13:07:08  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Over Volt is Unreadable
[?]  Mon Jul 29 13:07:08  [node-a: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Over Curr is Unreadable
SP-LATEST-IPMI
PSU2 Bad                                  TRUE
PSU2 FRU Power                             OFF
PSU2 Pwr In OK                           FAULT
PSU2 Crest Factor        critlow            0        1000          --        1728        2000
PSU2 InPwr Monitor       normal             0 mW       --          --          --          --
node-b
EMS
[?]  Mon Jul 29 13:07:06  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Temperature is Unreadable
[?]  Mon Jul 29 13:07:06  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Current is Unreadable
[?]  Mon Jul 29 13:07:06  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan1 Speed is Unreadable
[?]  Mon Jul 29 13:07:06  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan1 Fault is Unreadable
[?]  Mon Jul 29 13:07:06  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan2 Speed is Unreadable
[?]  Mon Jul 29 13:07:07  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fan2 Fault is Unreadable
[?]  Mon Jul 29 13:07:07  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Pwr Out OK is Unreadable
[?]  Mon Jul 29 13:07:07  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Fault is Unreadable
[?]  Mon Jul 29 13:07:07  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Over Temp is Unreadable
[?]  Mon Jul 29 13:07:07  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Over Volt is Unreadable
[?]  Mon Jul 29 13:07:07  [node-b: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Over Curr is Unreadable
SP-LATEST-IPMI
PSU2 Bad                                  TRUE
PSU2 FRU Power                             OFF
New to NetApp?
