NetApp Knowledge Base
AutoSupports using HTTPS via proxy in ONTAP fails with error"Received HTTP code 403 from proxy after CONNECT"
910
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
Applies to
  • ONTAP 9
  • AutoSupport
Issue
  • AutoSupports are being generated on the cluster but not reaching NetApp.
  • Notifyd.log is showing errors such as the following:
0000000d.0054f02d 0387a4b8 Fri Aug 12 2022 00:00:01 -04:00[kern_notifyd:info:1943] (category: 1943:0:deliver) (emittime: 8/11/202223:08:12) (message: Marked for [closure]: proxy CONNECT failure)
0000000d.0054f02e 0387a4b8 Fri Aug 12 2022 00:00:01 -04:00[kern_notifyd:info:1943] (category: 1943:0:deliver) (emittime: 8/11/202223:08:12) (message:Received HTTP code 403 from proxy after CONNECT)
New to NetApp?
