NetApp Knowledge Base
AFF A800 System had amber LED due to BIOS MRC MEMORY WARNING on Memory DIMM
1,095
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
HW
Last Updated:
Applies to
  • AFF A800
  • AFF C800
Issue
  • The node had a amber LED which was caused due to BIOS MRC MEMORY WARNING on DIMM.
  • The DIMM had mapped out on previous boot but the node was booted up which made the amber LED lit.
SP-LATEST-IPMI
hsamcmd --fault-show-all
tag  origin  fld                                     fault reason                                    count  time
1    bios    /chassis-1/controller-a/dimm-9          BIOS MRC MEMORY WARNING                         27     Fri May 10 22:27:05 2024
Fault Lights On:
             /chassis-1        27
             /chassis-1/controller-a        27
             /chassis-1/controller-a/dimm-9                                                          27
SP-CONSOLE-LOGS (Previous boot console Logs)
CPU reset.
[m[2J[HBIOS Version: 13.14
PEI start.
CPU PEI initialization.
Wait BMC self-test result.
BMC self-test: OK.
Running full memory initialization.
MEMORY WARNING: Major Code 0x30 Minor Code 0x2D DIMM:9.
DIMM: 9 mapped out. BIOS MRC mapped out DIMM. Major Code 0x0A Minor Code 0x03
DIMM: 9 mapped out. BIOS MRC mapped out DIMM. Major Code 0x0B Minor Code 0x1C
New to NetApp?
