AFF A400/FAS8300/FAS8700 BATTERY (wrong charge) WARNING on BMC 13.5 or later
Applies to
- FAS8300
- FAS8700
- AFF A400
- BMC Firmware 13.5 or higher
- ONTAP version with fixes for 1447722
Issue
- System generates the following AutoSupport alert
Call home for BATTERY (wrong charge) WARNING.
HA Group Notification (BATTERY (wrong charge)) ALERT
HA Group Notification (BATTERY (wrong charge)) WARNING
- The following messages can be seen in the EMS event log
[Node-01: env_mgr: nvmem.battery.wrongCharge:alert]: The NVMEM battery charger is charging the battery even though the battery is not requesting to be charged. To prevent data loss, the system will shut down in 24 hours.
[Node-01: env_mgr: callhome.battery.warning:alert]: Call home for BATTERY (wrong charge) WARNING.
[Node-01: env_mgr: nvmem.battery.normalCharge:notice]: The NVMEM battery charging status is normal.
