NetApp Knowledge Base
A400 node is unable to power on after Watchdog 2 Timer expired (OEM)
230
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • AFF A400
  • FAS8300
  • ONTAP 9
  • BMC (Baseboard management Controller)
Issue
  • The node unexpectedly shuts down and the partner node takes over due to loss of heartbeat:
Tue Jun 17 17:38:08 [partner_node: kltp: clam.heartbeat.state.change:info]: Heartbeats to node (name=source_node, ID=1001) are Failing.
Tue Jun 17 17:38:19 [partner_node: cf_main: cf.fsm.takeover.noHeartbeat:alert]: Failover monitor: Takeover initiated after no heartbeat was detected from the partner node.
Tue Jun 17 17:38:19 [partner_node: cf_main: cf.fsm.stateTransit:info]: Failover monitor: UP --> TAKEOVER
  • BMC  system log sel  shows watchdog messages:
a7 | 06/17/2025 | 12:18:14 | Power Unit #0xb2 | Power on | Asserted | from channel 1
a8 | 06/17/2025 | 12:20:39 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
a9 | 06/17/2025 | 12:20:45 | Power Unit #0xb2 | Power on | Asserted | from channel 1
aa | 06/17/2025 | 12:21:10 | Power Unit #0xb2 | Power on | Asserted | from channel 1
ab | 06/17/2025 | 12:21:57 | Cli_Reboot #0xb8 | bmc cli command reboot | Asserted
ac | 01/01/2000 | 00:03:15 | Power Unit #0xb2 | Power on | Asserted | from channel 1
ad | 01/01/2000 | 00:05:39 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
ae | 01/01/2000 | 00:07:49 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
af | 01/01/2000 | 00:15:44 | Power Unit #0xb2 | Power on | Asserted | from channel 1
b0 | 01/01/2000 | 00:18:10 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
b1 | 01/01/2000 | 00:20:21 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
b2 | 01/01/2000 | 00:29:53 | Power Unit #0xb2 | Power on | Asserted | from channel 1
b3 | 01/01/2000 | 00:32:22 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
b4 | 01/01/2000 | 00:34:33 | Watchdog 2 #0xb1 | Timer expired (OEM) | Asserted
  • Multiple sensors display No Reading status after shutdown
From BMC system log debug output:
PVCCIN_CPU0      | 01h | ns  | 21.1 | No Reading
PVCCIN_CPU1      | 02h | ns  | 21.1 | No Reading
PVDDQ_ABC        | 03h | ns  | 21.1 | No Reading
PVDDQ_DEF        | 04h | ns  | 21.1 | No Reading
PVDDQ_GHI        | 05h | ns  | 21.1 | No Reading
PVDDQ_KLM        | 06h | ns  | 21.1 | No Reading
P1V05_PCH        | 07h | ns  | 21.1 | No Reading
CX5_Temp1        | 14h | ns  |  7.5 | No Reading
CX5_Temp2        | 15h | ns  |  7.6 | No Reading
  • The node fails to power on after executing the system power on command from the BMC prompt.
  • The node does not boot even after performing a system power cycle from the BMC.
  • The node fails to power on after motherboard reseat.
New to NetApp?
