NetApp Knowledge Base
"sysconfig -r" doesn't display replaced disk after disk replacement in ADP configuration
394
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
Applies to
  • Advanced Disk Partitioning (ADP)
  • ONTAP 9
  • AFF and FAS
Issue
  • After replacing the disk in the ADP environment, "sysconfig -r" doesn't display the replaced disk.
  • "sysconfig -a" shows the replaced disk.
Before replacement:
        00.2 : NETAPP   X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXG5)
        00.3 : NETAPP   X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXRF) (Failed)
        00.4 : NETAPP   X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXET)
After replacement:
        00.3 : NETAPP   X343_SSKBE1T8A10 NA02 1713.5GB 520B/sect (WXXXXXBE)
  •   In storage disk show -partition-ownership outputs, Root and Data are blank, and  disk show -n is Not Owned status.
::*> storage disk show -partition-ownership
2.0.3    Container node-a        node-a        538164682   538164682
         Root      -                 -                 -           -
         Data      -                 -                 -           -           -                 - -
::*> disk show -n
  DISK       OWNER                    POOL   SERIAL NUMBER         HOME                    DR HOME
0b.00.3P1    Not Owned                  NONE   WBXXXXXXXX001
0b.00.3P2    Not Owned                  NONE   WBXXXXXXXX002
New to NetApp?
