NetApp Knowledge Base
Unable to login to the ONTAP CLI and System Manager using an AD domain accounts
416
Visibility:
Votes:
0
Category:
ontap-system-manager
Specialty:
OM
Last Updated:
Applies to
  • ONTAP 9.
  • ONTAP System Manager.
  • Active Directory (AD).
Issue
When attempting to login to the ONTAP CLI and System Manager using an AD
domain accounts, the following error is received:
"Sign-in has failed. Verify the username and password and try again".
  • Username and password are correct, but authentication failure is shown.
  • Users are configured with appropriate applications.
  • The following messages are recorded in Audit log and MGWD log.
Audit logs:
[kern_audit:info:3359] 8503e8000002f625 :: NETAPP-CLUSTER:http ::
XXX.XXX.XXX.XXX:10159 :: NETAPP-CLUSTER:admin@businessdomain.com :: Login
Attempt :: Error: Authentication failed.
[kern_audit:info:8959] 8503e8000002f625 :: NETAPP-CLUSTER:http ::
XXX.XXX.XXX.XXX:10159 :: NETAPP-CLUSTER:admin@businessdomain.com :: POST
/security/login HTTP/1.1 : ["X-Dot-Client-App: SMv4"] :: Error: 401
Unauthorized
MGWD:
[kern_mgwd:info:3359] 0x836024900: 0: ERR: PAM::PASSWD:
doLocalUserAuth:src/pam/pam_passwd.cc:892 Error: admin@businessdomain.com
entry does not exist in login table. Application: http: vserverId: 45855170:
username: admin@businessdomain.com Authmethod: password. Reason: entry
doesn't exist
[kern_mgwd:info:3359] 0x836024900: 0: ERR: PAM::PASSWD: pam_sm_authenticate:
passwd comparison failed for user(admin@businessdomain.com).
[kern_mgwd:info:3359] Error: PAM failed to authenticate user
'admin@businessdomain.com', application 'http', vserver 4294967295:
Permission denied
New to NetApp?
