NetApp Knowledge Base
System Manager does not display disconnected SAS cable as error
181
Visibility:
Votes:
0
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP System Manager
  • FAS2720
  • FAS2820
Issue
  • When SAS cable is disconnected, sas.cable.pulled event occurs but no error is displayed in DASHBOARD of System Manager.
[FAS2820-Node-01: pmcsas_admin_0: sas.port.down:debug]: SAS port "0a" went down.
[FAS2820-Node-01: pmcsas_admin_0: sas.cable.pulled:debug]: Cable attached to SAS port "0a" was pulled out.
  • SYSCONFIG -A shows system cable connection has transitioned from multi-path/Tri-path to single-path/multi-path HA.
[FAS2820-Node-01: svc_queue_thread: shelf.config.tompha:info]: System has transitioned to multi-path HA attached storage.
  • CLUSTER -> Hardware displays a SAS port icon that is only half gray, indicating that the connection is disconnected.
New to NetApp?
